Hi there,
I have a WB Greenstar CDi37 with a DT10RF Mark II. It's been about 3 1/2 years since it was fitted and has worked perfectly to date. The RF link seems to be fine and reliable between the DT10RF receiver & digistat.
However, recently the DT10RF digistat has started showing 0 degrees as the ambient temperature. Pressing any single button has no affect. Pressing < & > for 3 seconds does put the unit into user options. Pressing the > key again takes you straight to the Access Lock Protection Screen which is displayed as being On. Pressing + or - has no affect and I can't remove the lock.
Removing/re-inserting/fresh batteries has no affect.
My question is whether the digistat can be reset and would this clear the problem?
I've seen there is a CR2032 battery cell on the circuit board but it appears to be riveted on so the unit can never be completely powered down?
Otherwise does it need replacing? I understand that the DT10RF digistat is a rebadged Drayton +2 RF so could a DT10RF digistat be replaced with either a Drayton +2RF or +3RF?
Any answers very much appreciated.
