Worcester combi - system drain lever?
22 Mar 2021
Hello, re the attached image, someone told me that the lever pictured drains the system via the overflow pipe? Is this correct? I only ask as I plan to add a new radiator (in a bungalow) and thought this may be a good way to drain the system to add the new radiator. Thank you
Absolutely not...it locks the pressure relief valve in position and should never be touched.
