try and get a spark to show you. its much easier to watch and learn than to listen and learn.
[quote="chrishutt"]I don't think you should be using the multimeter until you have a better understanding of circuit diagrams and boiler electrics. If you don't know what you're doing you could do a lot of damage, probably to the multimeter and possibly to the boiler and yourself. I'm sorry if this sounds condescending but that's my honest opinion based on what you've said so far.
fitz1 said:try and get a spark to show you. its much easier to watch and learn than to listen and learn.
I don`t need a spark to demonstrate how a boiler works..he wouldn`t have a clue anyway.
quote="scatmanjohn"]Don't no too much about these yet so won't try and guess the fault.
One thing that confuses me about this boiler is the use of an APS.
Anyone know why it has one.
They seem to have added the APS for no apparent reason.
quote="fitz1"]MIs if followed will generally give you an idea of whats wrong and explain process of testing and fault elimination.
rather than spend in my case forever typing out what is already printed i advise you do a little research and so receive all accurate advise available for your appliance.except in the case of viessman.[/quote
I meant connect the two wires at the aps, which is what I wrote. Can't see how that can be clearer.Bridge out the APS,is that what you mean..I know you can do that with thermistors, do you mean that?
"Going through all that I have described", with the meter, would have taken half a minute or so...If you suspect the APS surely there must be a straightforward way of confirming your suspicions without going through all that you have described..
It's an APS you can adjust. To test with......What is an adjustable APS?..
He checks much the same way any boiler fixer would, which has been explained twice in different ways. What is there to not understand?...thanks to all for persevering so far...Still don`t know how Chrishutt checks with multimeter..
fitz1 said:Dont come on here judging me. im not the one struggling. if i can help , i will . im not a maintenance engineer but i do o.k. if im unsure i explain to customers i am unsure, but generally muddle through due to customer wanting me to because of a good reputation and success rate.Thats why i dont need to advertise.and also why other engineers ask for my services.honest, reliable,neat, clean,not a rip off,and very good customer relations.
ChrisR said:I meant connect the two wires at the aps, which is what I wrote. Can't see how that can be clearer.Bridge out the APS,is that what you mean..I know you can do that with thermistors, do you mean that?
You seem to be having trouble with basic stuff, and taking a pop at people trying to help you because you don't like, or can't understand, what they say. I suppose you'll have a go at me next?
