I am a plumber (but not a boiler engineer) and have installed a Greenstar Heatslave 25/32 oil fired boiler in a property in France. After a couple of lockouts due to air in the oil (dual pipe) feed, the boiler worked fine for about 15 mins and had just started to heat the pipes when it stopped firing. After turning on the direct hot water it fired again for a few minutes and stopped again. The pump and diverter valve are working fine and none of the reset switches need resetting. The fascia mounted programmer is functioning fine and the DHW and CH thermostats seem to be working (switching as they are turned up and down) but there is no power to the burner line from the control board. The burner/oil pump do not make any attempt to start when asked. As the burner does not try to start, I am unable to see if the oil pump needs bleeding. In my un-expert opinion, I am assuming there is a sensor problem preventing any power to be sent to the burner but have no idea where to start. I don't think this boiler is sold in France and assume a French engineer is going to struggle. Any advice would be immensely appreciated.
Many thanks,
Jeff Gascoyne.
Many thanks,
Jeff Gascoyne.
