Hi folks,
I've got a Worcester Heatslave 20/25 oil-fire boiler with issues! Recently its been causing problems and today seems to have given up trying! Here is the story of the symptoms so far:
- When running a hot tap it would give hot water for a few seconds and then go cold for maybe another 30s before returning to full heat. This started a couple of months back. It's been serviced since then with no issues found.
- It intermittently won't produce any hot water at all from a tap. This started in the last couple of weeks (post service)
- Central heating has been fine
- It changed so that hot water would only come out of a tap if the central heating was turned up. This started a few days ago.
The above symptoms made me think it was related to the diverter valve but taking the motorised head seemed to be working fine - with the lever on the side showing that it was going up and down at the correct time. The actual piston under the motor was a bit sticky a few weeks back but I freed it with a bit of WD40 and then looked like it was springing back to the normal hot water position ok. Could there be an issue with whatever is at the bottom of the piston within the brass three-port body?
But fast forward to this morning and the boiler isn't even trying to fire. It's not going to lockout and the burner reset button isn't illuminated. If I run a hot tap or put the heating thermostat up then I can hear the initial click from the control board but it's not even attempting to fire up.
I'm fairly convinced that its not a burner issue but is probably a sensor somewhere, maybe the flow valve? A thermistor somewhere? Or is there a sensor within the diverter valve unit?
Any tips on troubleshooting please?
