Hi guys, i have recently moved into a new home, the last owner had a new Worchester Bosch 24RI condensing boiler installed last year.
Since moving in i have always, noticed the constant sounding of the main pump that is controlled off the 2 way valves (HW
+ CH)
Today i decided to have a closer look, the CH i found that works fine, But i noticed that the HW valve is permantly on, hense my pump sounding noises. I also noticed that there is a plastic wedge has been placed to ensure that the HW valve is always open, this also meaning that the boiler is always switched on.
I removed the plastic wedge, and both valves working fine and the boiler switches on and off as required using the thermostats.
But i have FITTED the wedge back in as I assume there must be a valid reason for this wegde, keeping the valve open that keeps power to the boiler and the pump active.
Can anyone shed some light for any reasons.
+ CH)
