working pressure at boiler
29 Jun 2006
tested a Baxi 105e in work today inlet\working pressure was bang on 20mb but dropped to 18mb then stabilised at 20mb again - is this normal?
and another thing...
I know how to get max output on a combi (high flow rate through hot taps), but how do you test the min rate, i have noticed that when a combi fires up on DHW the burner is at a low rate then whoosh!, is the low rate i mentioned also the min rate that should be used if adjusting the min rate on the gas valve?
Baxi 105e MI does not state how to obtain a minimum rate from the boiler. It just tells you how to adjust the rate (small nut and disconnect one of the modulation wires - though when the wire was disconnected the boiler would not fire).
it f**ing doesnt :evil:
I learn more on here than i do in college and work - so be greatful that someone (me) is learning the trade the proper way and not just getting my CCN1 and pretending i know it all, ripping off people working with gas appliances with minimum knowledge and generally being a completly crap gas engineer.
I love this job and this site is simple the best thing that i've found so Kevplumb please teach me somemore you git :lol:
just looked under the sites 'profile' icon but cant see anything that says show/hide email?
found it :oops:
why do you want my email - are you going to give me the greatest bit of info on becoming a successful engineer that the world has never heard?
no i will give you some advice based on experience and if you think you will learn that in a class room i'll set the scruff on yer (it will not be pleasant)
DJ don't take prisoners bonny lad :wink:
