Hi everyone.
I have recently purchased a house and moved in with the best benefit being a 6 meter by 5 meter workshop at the bottom of the garden.
Now, upon moving in and closer inspection, there are a few issues. Doors don't fit, security is a major issue due to door frame rot etc. These issues, I can deal with.
The temperature in this workshop is around 1 degree when the outside is 10/15/20 degrees. It is built one skinny breezeblock thick all the way around with supporting pilars in the corners. Now, I want to use this for some computers, tv's and some serious server hardware however the building is causing condensation.
I have read the condensation posts and realise that I need to raise the temperature however here is where I fall down.
How can I complete the build of this workshop? How do I insulate the walls? If I just get plasterboard and put it on the walls, does this retain heat? The roof is open with support beams on show throughout able to see up to the peak of the pointed roof. Plasterboard the roof and insulate there? Floor is solid mortar, not necessarily level. Do underlay and carpet hold in the heat?
I really need a priority list of which will do the best job as I am low funded due to the house purchase and need to make this room habitable as soon as possible. I also need to vent the brick work somewhere and a any advice about where I should position the vents would be good (top middle bottom / corners, middle of the wall etc)
Thanks guys and gals, I'm a very amateur DIYer but recently things have been going really well. I'm confident but cautious as the moment
Take care!
Take care!
