WP Joint
10 Jul 2006
Cleveland
I'm wanting to extend 2.5mm T+E outside in garden. Would cold pour straight joint kit from screwfix do the job? How reliable are these as i've not used them before?
How is the T&E installed? What is it for? Is it worth replacing the T&E with something more robust like SWA? Are you a member of a competent person scheme (re Part P)?
T+E is in conduit feeding a pump, council are signing off part p as all work is part of extension. Its fed from 6A RCD
cold por kit wont fit in conduit.
why not crimp and sleave it in a conduit throghh box? (obviously put gasket on box)
I take it as it is underground that you are using metallic conduit? Is it possible to pull a new length of cable through using the old one as a draw wire?
I can remain silent no longer. This has been going on for years and it drives me nuts every time I see it.
Breezer, it's spelled sleeving.
Phew, thank god I got that off my chest. :D :D :D
