If you or your sparks has one of these all is not lost.
http://www.screwfix.com/prods/24300/Drill-Bits/Holesaws/Hole-Cutters/Adjustable-Hole-Cutter-40-205mm
My wife changed her mind on some down lighters so I ended up with the same problem.
From a sheet of 12.5mm plaster board I used the cutter to make plugs that were a tight fit in the holes. I then used a PVA glue to fix the plugs in the holes. The next day I very gingerly used to cutter to drill the plugs and form the new holes.
I set the plugs back slightly so when they were made good the joints were lost.
