Y Plan
7 Nov 2005
Cleveland
Could someone confirm what a Y Plan refers to.
I think it's when the system can supply heat to the water & heating separately or both at the same time.
Is this correct :?:
What I'm working round to is a question about the bypass valve.
I understand that it should be open enough to suit the system.
But one recent reply stated that it should be closed if on a Y Plan.
Since closing it down, but not fully, the boiler seems to be staying on longer, as it was shutting down too soon.
Not sure whether I should leave it as now set or close the valve down completly. :?:
Changed a honeywell divertor vlv on a W plan today
I love inch BSP
Still have em down here aswell!
Dave
And heatstore cylinders have them as well.. But have not seen one on normal system for a very long time
leave it about 1/4 - 1/2 turn open :wink:
Make sense as more water will be going around the heating circuit so the return temp at the boiler will be lower so boiler won't cycle off and on so frequently.
If bypass was open too far before it would have prevented sufficent water going around the heating circuit - have you noticed the radiators being any hotter or the house warming up quicker?
Eh? Why would you need a bypass on a Y or W plan system?
