In fact I'd even say that test was too strict as the wireless alarms transmit at a higher power than a car keyfob
That statement proves you need to research before making statements about radio equipment.
The important factor is not the transmitter's power but the signal strength at the receivers.
The communication between a car key fob and the care is far more sophisticated than the simple communication used in the average DIY alarm system.
As the degree of interference.
An incident involving failed radio communication led to an enquiry pending legal action against the supplier and installer of the equipment.
Test results using a transmitter and receiver typical of those used in the system involved. Operating frequency 433.xx MHz
Packets sent at 5 second intervals for 2 days.
Non-compelled protocol ( sender cannot be aware of lost packets so cannot repeat packet if lost. )
Environment one
Free field ( one mile from nearest building )
Distance between transmitter and receiver 30 metres. Over 30,000 packets sent without loss.
Environment two
The average of five locations on the edge of towns. Distance less than 20 metres One packet lost in every 27,000 sent
Environment three
The average of four locations in residential areas. Distance less than 20 metres One packet lost in every 17,000 sent
Changed to semi compelled single repeat ( if sender does not receive an acknowledgement then the packet is re-transmitted once )
Environment three improved to a total of 4 packets lost in over 120,000 with 3 lost at one location.
The test was repeated at the environment three locations with the senders set to test for clear channel before transmitting and without repeats. No packets lost in 20,000 Delays before transmitting were not measured but rate of sending dropped from one every 5 seconds to an average of one every 8 seconds.
From the expert witness giving evidence to the enquiry
The conclusion from these tests is that WI-NCCP systems are affected by other transmissions and therefore I would not endorse their use in this application. I would set a minimum requirement of WI-SCCP for this type of application and it is my considered opinion that ********** & Co were negligent in their assertion that ********** was fit for purpose in this application.
WI = Wireless interconnect.
NCCP = non compelled communication protocol
SCCP = semi compelled communication protocol
