YOU MIGHT NOT NEED TO REPLACE FILLING LOOP , READ!
16 Jan 2010
West Midlands
just fixed a problem after years of ongoing speculation , including "trained" homeserve engineers replacing the prv , twice! As you look at filling loop tap horizontal is closed and vertical is open whilst turning it clockwise , HOWEVER!!!! as I have just discoverd if you turn it a fraction to far so its at 12:01 rather that 12:00 position it slightly opens it back up and therefore ................releases water into the bolier , problem solved at no cost at all , thanks.
My question to you is- why is the filling loop connected? The flexi pipe should be removed after the system has been pressurised!!
Its taken years to work that out :D
As above ,loop should always be disconnected,then you would have spotted it in 2 minutes.
Why have you posted this comment in 2 different topics?
Anyway, wasnt it burnerman who told you to check the loop was fully turned off?
How wmany times have you actually seen that done in a house! My Vailent has the filling loop incorporated under the boiler, how many people would bother to disconnect that.
indeed.. from what ive seen, they are always left connected.
Have you ever seen a Ariston Microgenus?
It is difficult enough talking people through operating one,To connect it as well would be impossible.
If cheap and nasty rad valves were not used on installs,Many would not need topping up.
Does Microgenus not have two valves for positive isolation?
all my installs have loop disconnected, as long as customer is informed what to do if pressure drops before service why leave it on?
iv been to loads of *leaking pipes outside* that were filling loops still connected and passing.
because they work for homeserve , for those of you that are not aware homeserve are a company that are supposed to tackle , heating , plumbing , carpentry , roofing , electricals and everything else you can imagine , in my experience all of their staff are experienced in one of these fields and the one that turns up is not necessarily the one for the job so he calls the relevant one and the guy on the other end tells him what to do , therefore your guy is working almost blind
rubbish homeserve do not send carpenters to boiler faults and vise versa.
Might explain a few things though.
Homeserve are a joke.
They got paid by insurance to fix a broken window in my house - they boarded it up on the first visit as they said they had to go back to depot to get glass cut (unlike most sensible people who would have driven 1km to the local glass shop to get it cut). On their second visit, weeks later, they fitted the glass but cracked it with a nail too close to the edge of the beading.
That was in 2006.
They have yet to return to fix it.
