    Dismiss Notice
Zelio Logic 2 Smart Relay PLC
Discussion in 'Electrics UK' started by fezster, 7 Feb 2018.
  1. fezster
    fezster
    30 Jan 2013
    507
    Thanks Received:
    60
    London
    Country:
    I've not done anything with PLCs before but have a project I'd like to automate at home.
    Is anyone familiar with this model? Specifically, I need to control 2 x 240V outputs based on 4 x 240V inputs. I believe this would be appropriate:
    Mfr. Part No. SR3XT61FU
    https://uk.rs-online.com/web/p/logic-modules/4684309/
    Any pointers on getting started? Does this come with a USB/serial lead to program it?
  2. Sponsored Links
  3. Seb101
    Seb101
    29 Jul 2015
    271
    Thanks Received:
    8
    Country:
  4. Seb101
    Seb101
    29 Jul 2015
    271
    Thanks Received:
    8
    Country:
  5. fezster
    fezster
    30 Jan 2013
    507
    Thanks Received:
    60
    London
    Country:
    Thanks, looks like the USB adapter is required to program it. In which case, the Allen Bradley 810 may work out cheaper (it too requires a USB adapter, but it's significantly cheaper).
    I was hoping someone could suggest a cheap PLC for a very simple use case - to be able to control AC outputs dependent on multiple AC inputs for boiler control.
    I need to monitor 3 x 240V inputs and switch 2 x 240V output. However, every time one of the inputs is activated, I need one of the outputs to disengage for a period of time before re-engaging.
    So as an example:
    1. Input 1 is 240V. Output 1 goes to 240V. Output 2 goes to 240V.
    2. Input 1 is off. Output 1 and Output 2 go to off.
    3. Input 2 is 240V. Output 1 goes to 240V. Output 2 goes to 240V.
    4. Input 1 goes to 240V. Output 1 goes to off for 'x' seconds, then goes to 240V. Output 2 stays at 240V.
    5. Input 2 is off. Output 1 and 2 stay on.
    6. Input 1 is off. Output 1 and Output 2 go to off.
  6. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    Ah - the old quote-instead-of-edit trick :mrgreen:
  7. Seb101
    Seb101
    29 Jul 2015
    271
    Thanks Received:
    8
    Country:
    Doh!
  8. Sponsored Links
  9. magicmushroom666
    magicmushroom666
    11 Jan 2010
    274
    Thanks Received:
    51
    Essex
    Country:
    Pretty sure what you've linked is just an IO expansion and no good on its own. The small zelio PLCs need a special lead which is additional cost and a pain.
    Many new small PLCs now such as a Siemens LOGO or Allen Bradley 820 use ethernet to program so no special cable, and the software can be downloaded for free. Also the software is professional, well documented and easy to use.
    Of course for a one off home job, its probably good enough to just use a cheap chinese PLC off ebay or amazon etc and do battle with the software once.
  10. fezster
    fezster
    30 Jan 2013
    507
    Thanks Received:
    60
    London
    Country:
    Thanks. Would you say that around about £100 is right for a 240V 4 input, 2 output PLC?
    Just want to ensure I'm not way off the mark in terms of what I'm looking at.
  11. crystal ball
    crystal ball
    28 Apr 2004
    3,805
    Thanks Received:
    229
    Country:
    I have used Siemens Logo for a few panels I have built, there is evaluation software on the website and a good forum for queries
  12. SimonH2
    SimonH2
    4 Nov 2010
    5,674
    Thanks Received:
    576
    Cumbria
    Country:
    One more vote for the Siemens Logo - though it's "a few years" now since I last used one. When they first appeared, it was a significant step in cost/function and accessibility in low end PLC.
    The software does either ladder logic or block functions. I used the latter as it was then very much like digital logic design with discrete TTL or CMOS chips - ah, the days of building everything with 74LS and 4000 series chips.
    • Like Like x 1
  13. ericmark
    ericmark
    27 Jan 2008
    17,117
    Thanks Received:
    1,563
    Llanfair Caereinion, Nr Welshpool
    Country:
    When I was programming Siemens software was expensive so we never used that make. Ladder is normally not to bad to program in don't think any still use booleen logic as method to program plc but how some one would find programming I don't know. To day there are other options to the full blown plc.
    I would say start out with what you want to do there may be a easier or cheaper method.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
