Background:
I have a Victorian terraced house with original slated roof.
Since moving in a year ago, I have had a persistent leak which no-one has been able to fix. During periods of rain, the wood at the leaking point gets wet, it very rarely drips, but it does get very wet. The wet occurs on the top sarking board, so the leak can only be there or above (ie the ridge).
The suggestions from various roofers who have been out have differed. Some say they have fixed the leak, and that the roof is fine, only to never return my call when I ask if they can come back and have another look as it's still leaking. Others suggest the ridge should be replaced and a section of the roof be reslated near the top, while others suggest that the whole thing needs reslated.
Obviously the difference in cost between these options vary massively (quote for reroof is £5100 using Spanish slate).
I have attached 3 links to photos of the roof to give you an idea of its current state. I don't know a huge amount about how a roof should look, but I know that the only visible leak is the one I mentioned above. My half of the roof is half closest to you when you look at the photo.
You can see where various repairs have been done with some kind of covering up on the ridge, where people thought the leak was.
Would appreciate if I could get your opinions on the state of the roof and whether it needs replaced, would do fine with just some tlc and tidying up etc.
Note the images are about 2Mb in size, which allows you to zoom in massivley
Thanks very much
http://www.flickr.com/photos/11636925@N07/2202899569/
http://www.flickr.com/photos/11636925@N07/2203690614/
http://www.flickr.com/photos/11636925@N07/2203689952/
Thanks very much
