I'm making the preparations for installing a new split load cu. Before I do this I am going to install an isolator between the meter & the existing cu.
I'm ready to pull the service fuse (existing cu isolator off, gloves and goggles on, alternative source of light on, lead seal cut), but as I have not done this before I do not know what to expect:
does it pull staright out?,
is the outer plastic cover and the fuse integral or are they 2 separate pieces?
does it require much force?,
is it much like pulling out a fuse on the cu?
will any live parts be exposed once I have pulled it out?
Any advice would be much appreciated.
