You're wrong.A single spur from a ring circuit in 2.5mm TE can handle 1 x double socket.
You're wrong.Adding on a 3 socket fitting could / will overload the circuit.
That's exactly what's he's already doing.Best thing to do is to fit a 13A fused spur before the 1st socket to prevent overloading on the existing single socket and the 3 way socket you intend to fit.
There will be three sockets, not four.So you will end up with a max load across the 4 socket outlets (1 +3) of 13A x 230v = 3000w (about!).
It's also fine for heavy loads, such as a washing machine, tumble dryer, iron, or fan heater. In fact, anything that can be plugged into a socket.That's fine for light loads such as a digital TV, a lamp etc..
Why not? What do you think would happen?You will have limitations, so plugging in say electric heating, an iron, hair straightners isn't sensible.
There would still be a load restriction.The only way to avoid the load restriction is to open up the ring that the spur is fed from and make both the existing single socket and the new 3 way socket part of the ring.
So what can a single spur cable handle via 2.5mm TE
So what can a single fused spur handle via 2.5mm TE
So you think a 13A fused spur with 1 x single and 1 x 3 socket fitting will cope with 4 items plugged in, all drawing 13A
Thanks for the correction![]()
How do you get that ? The fused spur limits the total loading of all sockets beyond the spur to 13A, after that it's change spur fuse time.
If your going to contradict, please offer accuracy- ambiguity isn't helpfull.
Why not? What do you think would happen?You will have limitations, so plugging in say electric heating, an iron, hair straighteners isn't sensible.
Doh, lets guess![]()
More than 13A. That's thir-teen Amp-eres, using multi-syllable nomenclature.So what can a single spur cable handle via 2.5mm TE
13A (please see above for the remaining syllables).So what can a single fused spur handle via 2.5mm TE
Of course - it will handle it by blowing the fuse.So you think a 13A fused spur with 1 x single and 1 x 3 socket fitting will cope with 4 items plugged in, all drawing 13A
You're welcome.Thanks for the correctionThat's exactly what's he's already doing.Best thing to do is to fit a 13A fused spur before the 1st socket to prevent overloading on the existing single socket and the 3 way socket you intend to fit.![]()
Well then, change the fuse.How do you get that ? The fused spur limits the total loading of all sockets beyond the spur to 13A, after that it's change spur fuse time.It's also fine for heavy loads, such as a washing machine, tumble dryer, iron, or fan heater. In fact, anything that can be plugged into a socket.
Please explain which of my contradictions was incorrect. Or ambiguous.If your going to contradict, please offer accuracy- ambiguity isn't helpfull.
I have no need to guess - I know exactly what will happen.Doh, lets guessWhy not? What do you think would happen?You will have limitations, so plugging in say electric heating, an iron, hair straighteners isn't sensible.![]()
I'm saying no such thing. Which one of my "monosyllables" confused you?But not at the 13A that the fused spur gives. Are you saying that the ring extension option wouldn't be better ?There would still be a load restriction.The only way to avoid the load restriction is to open up the ring that the spur is fed from and make both the existing single socket and the new 3 way socket part of the ring.
If I take a fcu off a ring then a socket off of that is it orite?
so the single box has a supply spurd from the ring and an out going cable to the socket. So if I make that a fcu that's ok?
So, he intended to fuse the spur, then run three sockets (or doubles) off that.Can I put a triple socket on instead of the new double socket?
I pointed out that this is exactly what bertken is already doing.Adding on a 3 socket fitting could / will overload the circuit.
