Loft power
10 Oct 2010
London
Can i add a socket in the loft by connecting to the last socket on my upstairs radial circuit, or do i need to run a separate feed to it?
It's quite likely that you could, subject to test......
Do you possess any test instruments?
Lucia.
What do you need to plug into the extra socket?
What is the radial cicuit fused at?
What is already using this circuit?
The present fuse is a 20A MCB.
The socket in the loft will only be for a TV/Satelite arial booster.
