A question for the fellow sparkies ..
I'm just about to start a middle flat rewire (no great problem) but as usual the walls are solid all round with fancy cornicing. I'm hoping to use the existing lead sheathed cable where possible as draw wires as these can be seen from the hall. I would prefer to use single T/E cables to the lights rather than try and pull thro 3 at a time so that eliminates the loop-in method.
This gives me 2-options for the lighting circuit
1. central joint box
2. nuetral joints at the swiches (preferred option)
I did the 16th edition awarenes course a few years back and the way the 16th edition sometimes leaves things open to interpretation I'm not entirelly sure if this is 'allowed' although I don't see any problem with it ...I'm open for advice!
