Hi all,
What I want to do is operate a light from a automatic garage door fob, when you operate the door there is 230vac output from the controller. What I was thinking was if the output voltage could trigger a Latching relay (Im thinking latching as when you press the button the relay will latch - light is on, when they press the button to close the door relay will release - light off)
I've not had much experience with relays so appreciate your help, I may have got the whole latching relay wrong in my head. Any advice as to which one to use as well would be good, Rs have soooo many to chose from. It needs a 230v coil and able to switch a 100w load.
Cheers
Cheers
