I've been telling him that for the past few hours but he is not listening.Yes, I know, so connect the L and SL to the slave at the landing.
And I haven't a clue why he is insisting on introducing a JB into the circuit.
Is this what you propose ? Done a re-sketch I do appoligise for not listening before I am new to all this and do want to learn from what your saying![]()
It does. It's the same wire.Looks to me like the load has to come from the downstairs master though :/
NO You need
Landing light. Landing master. Downstairs slave.
3 core cable (+earth) from master to slave.
EXACTLY as the drawing in the Varilight installation instructions.
Is that what you meant to say?NO You need
OK, so 2 gang master downstairs, and a 1 gang slave upstairs?
That will work, as mentioned a few times above, the load and the live can be at either end - assuming the same lighting circuit is used.
EDITED
As for the junction box - you may be better with something like this:
Given the problems you have had trying to decipher a relatively straight forward two way lighting circuit, do you really want to start messing about that multi-wired (possibly ten or eleven cables) junction box.What are these called mate and where does the power from fuse box go into that it don't show does it ? Do screwfix/toolstation sell them ? Thanks
