morning,
my next door neighbour has a new hot tub arriving shortly and asked if i could look at his CU and see if i could suggest if everything is in place and what would need doing. (why he is asking me i am not sure)
Board 1 - He has 1 x 60amp main fuse feeding 4 x 30amp wired fuses (sockets up and down, cooker and shower) and 2 x 6amp wired fuses (lights up and down) on a board that has 2 slots left.
Board 2 - He also has another 60amp main fuse feeding 2 x 15amp wired fuses ( 2 x storage heaters) on a separate board which has no slots left.
Is a TT system with the line coming in overhead. not sure where the spike is (will need checking)
The Gas is bonded however the water is not.
He wants the 5.5kw hot tub out the back of the house with little expense however for the job to be done within current regs. (and yes i know this is notifiable)
My thinking is to leave Board 1 alone ( apart from update the wired fuses with slot in mcbs or do they need to be slot in RCBO.s assuming these exist? and bond the Water.
Renew the Board 2 with say a small 5 way with 63A 30mA RCD. Get 2 x 16amp mcbs for the storage heaters and 32amp for the Hot tub.
Then all i need to worry about is the hot tub.
How does that sound chaps or am i way off the mark.
Many thanks.
![Question :?: :?:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Many thanks.
