I have just had the boiler replaced. I am told that the gas pipes need to be earthed. The engineer proposes to run an earth wire (10mm) from the mains water pipe (where it enters the house) to the gas meter. He also wants to use an earth block at the electrical distribution box and run earth wire (10mm) to the mains water pipe. The access is not difficult and the earth wire runs, I estimate conservatively, would be approx 10 metres in total for both of the above.
I would have thought that the electrical distribution box would be earthed anyway – an absolutely basic requirement. I do not know how to check this. I have looked around the box to see if I can spot the earth wire anywhere – however I do not know what I should look for as the wires all have sheaths around them. Any thoughts or ideas?
If he has to carry out the work he proposes, what would be the likely cost, noting he would not make a separate visit to complete the above (i.e. it would be part of other work)?
