ok so after this thread:
http://www.diynot.com/forums/viewtopic.php?t=154004
It's got me thinking, while i'm plumbing in this shower it might actually be an ideal time to remove the tank from the loop all together. I cant say i like the idea of drinking/brushing my teeth etc with water thats sat in a tank for god knows how long, especially after the showers installed as the only thing using water from the tank would be the sink and toilet (and the bath but then that would rarely be used anyway).
So if i were to simply shut off the mains and drain the tank, then connect the mains water feed that used to feed the ballcock valve directly to the tank outlet instead, would this be acceptable?
My first concern was that the fittings in the bathroom arent currently rated for mains pressure, however seen as both the bath and sink are currently being fed hot water from a combi boiler they both effectively are already dealing with mains pressure. So that just leaves the toilet, which i'd imagine should be streight forwards enough to change, if need be?
Anything else i should think about when doing this? or does it sound sensible enough?
