Builder's wiring!
31 Aug 2008
West Midlands
Went to a job and the builder had disconnected the security alarm from the fused spur and wonder why the breaker wouldn't reset?
[/img]
Don't tell me, he called you up and told you to bring a new circuit breaker?
Makes a change for it not to be the alarm fitters at fault... Had one a while ago - this a big name national alarm company I probably shouldn't name- spurred the 1.0mm alarm feed off the incoming side of the fuse board isolator.
At least its safe. Went to a site today, extension being added, found three cables just chopped off by the builder and still live.
Old Wylex board = no RCD. :roll:
The one that took the biscuit with me was seeing someone with a mains drill and a 1m long bit drilling a hole in the bottom of a full swimming pool to mount a hand rail. They also had a very long extension lead to reach the socket in the plant room outside (which wasn't RCD protected.)
More common than you think- the "idea" was to give the panel a UPS.... :shock:
Seen it once or twice, but this was the biggest name in the biz, I should know better than to think that should mean something, but y'know.
okay here's one, plumber called up and said he's damaged a pyro, is it okay to put some tape on it and push it out the way...
doped up plumber + pipeslice + unsheafed pyro submain that "looked a bit like a water pipe"=
Nightmare.
Looks old enough to be imperial.
That'd be a new submains then.
Oops :lol:
Nightmare.
Oops :lol:
yeah, 3pm on a friday so chucked a length of armoured in.
fused @ 60A in the cut out.
Don't think the guy realised how close he came.
