Hello everyone,
I'm hoping someone will be able to advise me on this.
Several months ago the shower unit began to cause us some problems in that water was dripping into the kitchen directly below. I found a similar problem on this site and I followed the advice given; removed all the sealent from around the edge of the tray and replaced it, likewise around the waste. I put a couple of heavy items in to simulate weight when one of us was actually showering as suggested. Everything seemed fine for a couple of weeks but then it happened again.
So, I then removed the skirting to look under the tray. The whole unit has been built above the floor and is held up by two large supporting blocks of wood on top of which is a sheet of hardboard and then the shower tray on top of that. I think that there is a gap between the hardboard and the base of the shower tray, but I can't confirm without taking the whole unit apart.
After taking the skirting off I discovered that the problem was that some idiot, had simply shoved one bit of plastic pipe up another bit of, slightly larger, pipe and this is what passed for the trap!
Oh, how we laughed... Err, well no, actually. So, off to the local builders merchant where they didn't have a shallow trap. Off to toolstaion where they did but of the wrong size. Luckily a new B&Q had (almost literally) just opened and we managed to find a shallow trap that would fit the existing waste and was shallow enough to fit between the base of the tray and the floor. Excellent!
Fast forward a couple more weeks, leaking again! This time, not from the trap, but from somewhere else I wasn't sure of. Re-sealed all possible bits. Held for a few more weeks until I discovered that it was again leaking this time from a bit that... Oh, this may be difficult to explain. OK, you know in most shower units the waste is level with the base? Well, in this one it sort of drops down. So there's a tube, as it were, with a neck that's level with the tray, but the actual waste in dropped down by about 3". Hope that makes sense? So, I found that it was leaking from that bit. I assume water was getting under the "neck" part and running down the outside of the tube, which is where it was dripping onto the floor... again!
Out with the sealant again. This time I decided to have a proper nose under the "neck" and found that the rubber washer had perished. I did try and get the tube bit out, but it wouldn't come. It's got a screw thread on it but doesn't actually screw onto anything. So, as I couldn't remove it I just had to seal it again as best I could. It seemed to be working fine until the day before yesterday when it was dripping through the kitchen ceiling again.
So, that's it. I have now come to a stand still and I have no idea what I should do next. I was hoping someone on here would have some ideas about where I'm going wrong! Would it be possible, for instance, to buy the right side rubber washer and stretch it across the "neck" to get it in place? Not ideal, but since I can't remove it I don't know how else to get a washer in place. Is there a recommended brand of sealant that I would be better off using? Should I just take the whole lot down and chuck it out the bathroom window? Any advice would be greatly received!
I can upload some pictures of the shower-tray-from-hell if that'd help?
Many thanks in advance,
Ex.
Ex.
