Aavantaplus control systems - a question for Bigburner
18 Oct 2007
Kent
In another topic,
Bigburner said:
Yes, a good boiler with weather compensation is the key. Broag Avantaplus are well priced, excellent quality, and have excellent control systems - OpenTherm.
Fit a 3-way diverter valve on the system with quick recovery coil in the cylinder giving DHW priority. The Avantaplus control system will run the boiler to maximum temperature to re-heat DHW ASAP. When DHJW satisfied it returns to weather compensation for CH control keeping the return temperature as low as possible.
Where did you get the information about the Avantaplus control system running at max temp when heating hot water and returning to weather comp for CH? There is nothing about this in their literature, although some of their wiring diagrams show diverter valves and others show the traditional Y-plan with a mid-position valve. What would happen if a mid-position valve was used instead of a diverter? Would the boiler run at max temp or at weather controlled temp?
I'm interested as I have decided to install an Avanta 18v, when my existing Apollo Fanfare boiler gives up, and want to maximise the investment by using weather compensation etc, but I don't want to spend money on a diverter valve if I can retain my existing mid-position.
As per a previous thread, we have fitted exactly this configuration on an Avanta 18v in Haywards Heath, it is pictured in the Avanta brochure.
You will need to fit a spring return diverter valve rather than a mid position. The diverter valve can be biased off either way, because there is a changeover switch in the relay outputs on the 18v board (but only one output is listed in the manual, confusingly).
Big Burner won't be aware of this because he hasn't fitted one. :lol:
This like saying an architect doesn't know about buildings because he has never built one. Hilarious!!!
I specify and others, like you, do what I say. ;)
Are you referring to anyone in particular when you say 'others'?
An architect has a visible portfolio of work, whereas you have, to date, said a great deal and delivered nothing tangible.
I think an architect would find your personal comparison insulting.
In another topic,
Fit a 3-way diverter valve on the system with quick recovery coil in the cylinder giving DHW priority. The Avantaplus control system will run the boiler to maximum temperature to re-heat DHW ASAP. When DHW satisfied it returns to weather compensation for CH control keeping the return temperature as low as possible.
Look at:
http://www.avantaplus.com/docs/Issue 5 -Avanta Schematics Booklet.pdf
AVANTA 18v System Only Option 5
Simple weather compensated Heating with 230v room thermostat override and Priority DHW
Also:
AVANTA 18v System Only Option 6
Simple weather compensated Heating with volt free room thermostat override and Priority DHW
A cylinder stat or cylinder temp sensor can be used. You program this via the boiler controls. The compensator slop is set in the boiler too. It come with a slope re-set which is fine for most rad systems.
Look at:
AVANTA PLUS System Option 19
System boiler - Internal time clock with simple weather compensated UF Heating and priority DHW
This has UFH. A high limit temp stat and diverter valve to ensure UFH pipe are not overheated. The flatter compensator slope can be set vi the boiler. This means the UFH can be ticking over at 35C and when DHW is called the boiler ramps up to max to reheat fast. When it reverts to UFH the boiler temp may be 70-80C, so the UFH high limit will cut in and send the hot water back to the boiler until the temp drops below the high limit and then compensator control again.
UFH invariably entailed complex controls, as boiler only gave one temperature at any one time. Few ran UFH from a boiler directly, unless it was a boiler assigned to UFH only. Weather compensation was a separate compensator unit. To have the one boiler do UFH & DHW the boiler had to run hot and a blending valve to reduce for UFH. Thermal stores were used and invariably run too hot, blending down for UFH via blending valves or weather compensation. However, I implemented thermal stores with a weather compensator set to a UFH slope heating only a UFH section of the store - no cycling and the correct temperature for UFH. But this was complex and few service men could understand it unless they specialised in UFH. I always left documentation and drawing of the system by the store, so they could understand. All this is extra expense.
This boiler can run UFH directly under weather compensation and still reheat the DHW fast - I prefer a DHW only heat bank. This was possible before with reasonably priced boilers. Ravenheat did have this facility except thee was weather compensation - and the reliability of this company's products meant this was not an option. This simplifies design and installation and reduces cost substantially. Only a low loss header may be used and an extra diverter vale. The header can be knocked up simply enough, or with an open vented system use a cheap 40 litre direct cylinder and the diverter valve eliminated just using a high limit pipe stat to the UFH zones. The cylinder will absorb any small amount of boiler water that is too hot - a nice CH buffer.
On some boilers with weather compensation you can get the same functionality out of the boiler but you have to frig it. Use relate to switch the outside sensor to a resistor to kid the boiler it is -5C outside and then it runs up to max temp. When DHW satisfied it will revert to the true outside temp sensor. Some makers do not like this, as their technical department don't understand what is going on - this is common in commercial systems.
The boiler has to be told in the many situations what the system is. Set via the boiler.
Some MAN boilers have similar control functionality, but these cost. The Keston and Broag now reduce the cost of UFH and the running cost too as UFH runs at very low temperatures. The Broag as far as I can see, has much better control configuration than the Keston - although the Keston I avoid until field feedback is positive on reliability. Many were bitten by the Celsius, while previous very simple models were very reliable.
The likes of you.
I didn't know you knew me - or think you do. You are intimidated by people who are more intelligent and knowledgeable. Like most hands on know-it-alls. Keep swinging on the core drill. :)
I am happy to learn from those who are more intelligent and knowledgeable than me.
There are plenty of people in that group but you are not one of them.
Look at:
Also:
I have read through the Avanta wiring manual very carefully and nowhere does it say that, when the diverter is in the HW position, the boiler runs flat out and, when in the CH position, it is controlled by the weather compensator. Are you just assuming this is the case or do you have solid evidence?
I worked out a wiring for an Avanta system using weather comp, volt free CH stat, cylinder stat and a mid-position valve but am unsure if it would work. May be I should run it past the Avanta tech dept?!
Then keep reading my posts.
youll probably know, all about hubris then.
Word for word that you used to post as Dr Drivel.
I would say the truth is that you specified, then the rest of us had to put right your mis-guided and specified installations.
bigburner is good at reading literature.
This time he is right. on the avantas when you wire the controls to the pcb board it has 2 connections for the cylinder stat and for the heating stat. when only the hot water stat calls for heat and the diverter valve comfirms that hot water only is being heated then it runs at the maximum temp that you have set the boiler at. if the controls call for both heating and hot water or heating only then it relies on the weather compensation.
These are good boilers but it takes a while to get your head around the setup procedures and the fact that you have to set the gas valve up on every install. ( i have fitted between 15 and 20 of these)
If you think a customer might want to play with boiler controls then don't one as they will **** it up after you leave!!!!
hijack post alert...!
snb, aq6000?? system A 2x mo valves, I have a problem with one,
are you clued up on them?
I am always right.
Think that through again.
Bigburner !
If you were an intelligent person and not retired, then dont you think that you would be a significant personality in the plumbing and heating world and be proud to give your real name and to promote your employer's name and products.
Of course its obvious to everyone that you are well retired and have no current connections with the industry apart from your forum rantings which are often well short of the mark.
Thats a pity because I expect that in your heyday ( 1970s ) you were a competent design engineer.
It would be better if you were to now spend your retirement days in the garden and relaxing on Saga holidays.
Doesn't it strike a note that I am happy to give my full name whilst you want to remain a non-identity?
Tony Glazier
