In another topic,
I'm interested as I have decided to install an Avanta 18v, when my existing Apollo Fanfare boiler gives up, and want to maximise the investment by using weather compensation etc, but I don't want to spend money on a diverter valve if I can retain my existing mid-position.
Where did you get the information about the Avantaplus control system running at max temp when heating hot water and returning to weather comp for CH? There is nothing about this in their literature, although some of their wiring diagrams show diverter valves and others show the traditional Y-plan with a mid-position valve. What would happen if a mid-position valve was used instead of a diverter? Would the boiler run at max temp or at weather controlled temp?Bigburner said:Yes, a good boiler with weather compensation is the key. Broag Avantaplus are well priced, excellent quality, and have excellent control systems - OpenTherm.
Fit a 3-way diverter valve on the system with quick recovery coil in the cylinder giving DHW priority. The Avantaplus control system will run the boiler to maximum temperature to re-heat DHW ASAP. When DHJW satisfied it returns to weather compensation for CH control keeping the return temperature as low as possible.
