No offence meant, but I suspect that it's a bit beyond your current capabilities.by the way do you think a powerflush is a diy job or not?
I don't understand - please restate.my thoughts on the magnacleam are that if i don't do a powerflush then it will take some of the crud out so is that a bad thing.
If you can't afford it, then don't have it done.i just can't really afford BG powerflush at 600 quid at the moment
By trying the cleanser first, you'll only lose the cost of it, plus your own time. If it doesn't work then you can still save up for the powerflush.
And yet it's the perfect location for a frost stat.Wot's that directly above the boiler? A room stat? Bit of an odd location?
