There is no room between the motorised valve and pump, but there is a pipe coming off the motorised valve which is hot, which would have enough room. would that work?
yes your right, your not supposed to fit an isolation on the vent pipe. But nobody has suggested doing this so its irrelevant.
thetinman said:Where do you fit the magnaclean? on the CH vent pipe?
At least 2 months too long.we tried using X400 and left it in for about 3 months
Try a double dose of X400, AND a Magnaclean, for about a month. Then replace any radiators that are still completely crudded up. In most houses the total bill will still be less than a powerflush.What would be better given the circumstances, powerflush or a magnaclean?
Although nobody would want to put a valve on the vent pipe, it's wrong to say "you cannot".you cannot have isolation valves on a vent pipe.
Wrong advice again. Fitting on the return is recommended.fitting it on the return is fine.
No it isn't.it is illegal on the vent pipe
Up the expansion pipe.where would the expansion of water travel whn the heating gets hot?
