Hello all,
I've made a bit of a mess sanding a victorian pine floor and would very much appreciate some advice on how best to correct it.
We starting off by sanding the floor using a hired belt/edge sander from the local hire shop, which came out okay. We then filled the gaps between boards with a resin based mix and fill mixed with the sawdust.
Now here's where we went wrong... we ran out of mix and fill before finishing the whole job, and had to wait a few days before we could get some more. In the meantime, the sander was returned to the shop and had to hand sand off the excess with an orbital. The mix and fill was a lot harder to remove than we anticipated, so we ended up using 40 grit sandpaper to shift it. We then gave it a quick once over with 80 then 120 (both with orbital) before finishing with 2 coats of osmo hardwax oil (satin).
Now as you can probably imagine, the finish is very patchy and has a nice sheen to the finely sanded areas whilst being very dull where the coarse paper was used.
And now onto my question: what can i do to achieve a decent, even finish across the floor? A person at osmo suggested applying another coat of hardwax oil with a polishing machine - but is this likely to polish out rough areas? And I'm thinking that if i'm going to trouble of hiring equipment again then I might be better off hiring a sander and re-doing the whole floor. Or could i get away with re-sanding with a hand belt/rotary/orbital sander?
Any comments/advice would be greatly appreciated!
Thanks,
Mike
Thanks,
Mike
