2000W Dimmer??
8 May 2008
Middlesex
Hi Guys,
I need some help locating a 2000W Dimmer. A local sparky informed me that i would have to special order it and would cost me about £80.
Can i order this online from any wholesaler as such?
Many thanks in advance.
Nav
What are you trying to dim with it?
Is it for a domestic premisis?
Is the wiring currently installed for the light(s) / switch?
I need it for commercial purposes. Yup the wiring is currently working on a single switch.
There are 4 chandeliers with 7 40W bulbs each.
total load to dim 1120W
Hence looking for a maximum capacity dimmer.
Thanks.
Is there any size constraints, or would apperance be an issue?
The reason I ask is if you are looking for a dimmer that size, you will not get anything on a standard accessory plate.
The biggest plate dimmer available is 1000W on a 2G plate.
Would you be able to split the load over two switches?
I'm having diffuculty finding a single channel dimmer with that capacity.
Would additional channels be any use to you?
<edit> Just seen 333rocky333's post. That looks like a good soloution.
Taylortwocities, sorry, but the link is for a remote dimmer, not a replacement switch.
If it was to be remote there are a lot of commercial lighting dimmers that may be suitable, but it looks like he wants just a switch
