... back to the drawing board
If your calcs are correct, P can't be on the far right of the grid so the useable grid will be narrower than 10 blocks. Run it again with a narrower grid values.
If GCS is at (0,0), as would be sensible in order that the position of one block south and one block east was represented by a grid location of (1,1), then the workplace is at (11,3). If GCS is at (1,1), then the workplace is at (12,4).
Why assume it? It's stated in the OP.I assumed GCS at top left corner of gridIf GCS is at (0,0), as would be sensible in order that the position of one block south and one block east was represented by a grid location of (1,1), then the workplace is at (11,3). If GCS is at (1,1), then the workplace is at (12,4).
Clearly....and although the grid is # blocks wide, there are #+1 vertical paths.
And yet, it is.The workplace can't be at east 3 or east 4.
It appears that you're trying to find a route from P to GCS, whereas the question clearly asks for a route to work, i.e. from GCS to P.You can't travel West so all the paths above and to the East of P are eliminated.
Greetings blondini.Hi Softus.
Reading my third point again, I disagree with it too.Completely agree with your first two points, disagree with the third...
...in which case I disagree with you.The workplace can't be at east 3 or east 4.
P is at 11 blocks south, 3 blocks east.
Doesn't seem like much of a jump to me.I will jump the gun at Gordo's workplace being at 11 blocks South, 3 blocks East.
My hearty congratulations Softus. Bearing in mind that the UK Junior Mathematical Challenge is set by 'The Acturial Profession' and is aimed at those gifted in mathematics, I am truly impressed. You have shown that the comment posted on the original question about the width of the river, was nothing more than jealousy and sour grapes. I speak of course of Namsag's post that claimed that your mathematical abilities couldn't even match those of a twelve year old. Do I hear a whispered apology from Namsag?P is at 11 blocks south, 3 blocks east.Doesn't seem like much of a jump to me.I will jump the gun at Gordo's workplace being at 11 blocks South, 3 blocks East.![]()
