Need to decide on shaver socket position before tiler arrives thurs so I can cutout a box in the wall.
Please let me know if this rings alarm bells in any experienced Sparks.
I attach a pic of where I would like it to go (the black rectangle in pic). This is within 60cm of bath edge = zone 2 in 17th ed regs.
Can raise it higher up wall if required.
I have a deep 47mm 2 gang box which I can attach to wood support behind plasterboard in the boxed position indicated.
Far enough above basin to prevent splash. Shower attachment on bath is demountable from wall. Regs state socket must be "located where direct spray from showers is unlikely". Does this scupper me even when a shower curtain or screen is used?
There is a clear run for wiring between joists from the ceiling light rose and the position on the plasterboard wall where I want socket sited.
I assume electrician will use a shaver socket that conforms to BS EN 60742. Cant get electrician out before thurs (a last minute decision)
thanks in advance
thanks in advance
