What do i use as a straight edge
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
i have been using a bowed roof lat to do some brick edging for my patio. it's ok, but i want something completley straight which is 2m long or bigger.
any ideas ?
How about the old favourite ..... a string line :roll:
Then it can be straight and level
My best solution is cheap white faced Contiboard, get a 150mm wide 2.4m length (assuming that's long enough). Stable and easy to man handle in most situations.... oh, and it's cheap :)
on site when cutting sheet material use the fence cut off the first 6" then use that for a strait edge making shure you mark the machine edge for running up against
6 " keeps it rigid [assuming 12mm] and allows the clamps to clear the motor
the conti board sound good. the line is obviously a good idea as well. but i like to use the board to tap down my line of bricks.
Don't forget the old site favorite for straightening up brickwork. A lump of 4x2 and a 14lb sledge hammer.
