Oops sorry missed that bitCompletely empty the house and move out![]()
The house would be totally empty with 100% access to lift-up floorboards and skirts.
Accessory heights of yesteryear in nearly every case would not pass today's building regs (Part P).
All moot points really since each LABC does what the hell it likes anyway.
No - the Building Regulations contain an explicit definition of "material alteration"Depends whether you consider the/a refurb to be a "material alteration" or not, I guess. Down to interpretation again.
There's sod-all they can do regarding Part M - the Building Regulations explicitly say that it doesn't apply to an extension of or material alteration of a dwelling....All moot points really since each LABC does what the hell it likes anyway.
I can't see that quoted phrase anywhere in the Building Regulations...."However, an extension of a dwelling, or a material alteration of a dwelling, must not make the building less compliant in relation to Part M than it was before"
They are plainly wrong, but since Liam is happy to have the sockets & switches at those heights it doesn't affect him.So it doesn't apply except in so far as it does apply, which is what it sounds like LiamPope's LABC are claiming.
Which Wiring Regulation says that?If it's a 17th Edition rewire the whole Part M thing is built in to the regulations. Heights of sockets and switches have to be between 450mm and 1200mm regardless.
That's because there isn't one. Part M is not built into the Wiring Regulations.Can't find a specific regulation having said that.
The On-Site Guide points out that "the Building Regulations require switches and sockets in new dwellings to be installed so that....".Pretty sure it's in the onsite guide
Who are - NICEIC?but during my last visit from my NIC area engineer they're taking the line that the new heights should be kept to.
No it won't!If it's a new installation like a rewire Part M will apply
What the regulations cover
The requirements with which building work should comply are contained in Schedule 1 to the Building Regulations and are grouped under the fourteen 'parts' below:
Part A - Structure
Part B - Fire safety
Part C - Site preparation and resistance to moisture
Part D - Toxic substances
Part E - Resistance to the passage of sound
Part F - Ventilation
Part G - Hygiene
Part H - Drainage and waste disposal
Part J - Combustion appliances and fuel storage systems
Part K - Protection from falling, collision and impact
Part L - Conservation of fuel and power
Part M - Access to and use of buildings
Part N - Glazing - safety in relation to impact, opening and cleaning
Part P - Electrical safety
Wall mounted socket outlets, switches and consumer units should be located so that they are easily reachable where this is necessary to comply with Part M of Building Regulations.
