How can this be?
If you are unsure of where your fuse box is, you can call your local electricity company and ask them where your fuse box is.
Yeah. Right.
Should I have told them that mine is now in a different position alltogether? :roll:
It did take me about 10 minutes to find one once on a periodic, behind pvc paneling :evil:
The video is still incorrect - says the main switch will normally be thrown into the off position when a fuse blows.
As for a lamp blowing a 30A fuse - there is something seriously wrong!!
Read Step 4,
How does the main switch on these flick itself into the off position when a fuse blows :roll: :?
http://www.wikihow.com/Change-a-Fuse-in-a-Wylex-Standard-Fuse-Box
Regards
Its a mishmash of quite dangerous advice, firstly from a British perspective (I wouldn't really want my hand near a 30a BS3036 when the supply was restored onto a possible dead short or, at the very least I'd want some warning of the effects of how it operates in the event of a fault, especially if I happened to be standing on a stepladder at the time!), and secondly from a transatlantic perspective.. "Never use a penny to replace a blown fuse...", "If you also smell propane or gasoline in your house, you should exit your house and call 911..."
All very confusing and misleading to the layman in this country...
