Hi there,
I would be grateful for a help with a combi-boiler related issue. I have been without hot water/heating for 5 weeks and have had three engineers look at my boiler, although no joy.
So far this is what has happended. The Ferroli Boiler is about ten years old has been serviced every 4 years. The red warning light popped on one day and would not go out. The first engineer came and cleaned/hoovered out the boiler and checked it over and suggested I needed a replacement 700 quid PCB. I did not trust this and got a second opinion, and it was discovered that one of the ignitor arms had snapped off! Anyway, I got a replacement from Ferroli a month later (!) and it was fitted. The engineer who fitted it still got a red light, but after fiddling with the position of the ignitor, it started working and the heating was working OK again. However, the release valve was dripping and after 20 minutes a trickle appeared, so back came the engineer. He replaced the release valve (the red one that springs shut when let go and reduces the water pressure) and we were back in business. After an hour test, we turned off the boiler.
That evening I went to turn the boiler on and noticed the bar pressure gauge was at zero. The boiler would not ignite or anything, and now the red warning light is back on as soon as I turn it on.
I read that the boiler may need its expansion vessel repressurised, except this boiler does not seem to have one! There is small unit with a tyre cap and thread, but the unit is tiny (like 5 x 4 inches). Air does seem to exit from it if I push a pin in it, but it seems far too small to be an expansion vessel??
Does anyone have any ideas what the problem might be?
I pressurised using the black tap under the boiler, to 1 bar (as recommended by the manual) but no luck - red light.
Regards,
Sophie
Regards,
Sophie
