Sealed system expansion vessel question(s)
So what you do then, is choose a charge pressure, eg 1 bar (as you stated earlier and I disagreed with)! then work out the static pressure (system pressure) and round up, ie 1.2M to 1.5 - then choose that constant figure next to that, ie 0.152 then times it by the system volume and then choose the next sized expansion vessel up?!!!
no as i stated earlier you work out the system volume first
you pre charge the system to 1.2 whigh allows for the head
not the bleeding expansion vessel
sorry :oops:
basically, work out the system volume, then buy the next size vessel up and pre-charge to 1-1.2 bar and that is fine....?????!!!!
kev-a final question please mate: for a domestic house (3 beds semi) - will a 12 L vessel charged to 1 bar be sufficient and operate correctly, even if it is slightly oversized and over-pressurised, from your experience??
wey yer booger if divvent knar wey i we tel ye
or you could have
welll i donn't reallly know beacause we don't do it that way over eeeere
ball park starting point :wink:
The answer to that question depends on the system volume, and the initial system pressure.
Most manufacturers give you the pre-charge pressure, you can work it out from there.
The only thing to remember is the pre-charge pressure must not be less than Hydrostatic head. :lol:
Young pups :roll:
Young pups :roll:
oy yer owld git :might have a few miles on the clock wink:
Work out an example from the list I posted.
System volume 100 Ltrs.
Pre-charge 1bar.
System pressure 1.5 bar.
Thats 100 x 0.152.
Can i go to bed now I'm missing my afternoon nap. :shock:
