Using charcoal as a method of cooking is nearly as old as man himself & the food is supposed to be cooked not carboniseddo you or not realise that carbonised food is responsible for the majority of bowel related cancers?
Using charcoal as a method of cooking is nearly as old as man himself & the food is supposed to be cooked not carboniseddo you or not realise that carbonised food is responsible for the majority of bowel related cancers?. It’s back to the odd burnt sausage & cremated burgers again, if the food ends up carbonised then your not doing it properly.
And cooking it properly is best done when you can control the heat. Which is much easier with a Gas BBQ. Certainly you can mess around burning yourself, poking the coals around, even spritzing the charcoal with water to damp it down a bit (invariably dusting all the food with a light coating of tasty nutritious ash)
Not convinced one bit.
No real point in continuing with this, you obviously have no idea how to cook over charcoal so a gas BBQ is eminently more suitable in your case.
I’d agree partly with that one.The only thing different, is that when cooking on a charcoal BBQ, you resemble a black 'n' white minstrel, and smell like a petrol pump attendant![]()
No I can’t actually, I generally think they are a rip off & never buy them. Only thing I do make sure of is I only to buy locally reared & butchered meat; more expensive but it’s one where you can definitely tell the difference.Don't tell me you can taste the difference between organic and non organic produce as well![]()
Well if you smell like a petrol pump attendant, you have obviously been doing something wrong, you do not use petrol or normal paraffin to light a BBQ, use the correct fluid, you need some advanced preparation, after lighting it takes approx 45 mins before it's ready to use, (I admit this is where gas has an advantage)And cooking it properly is best done when you can control the heat. Which is much easier with a Gas BBQ. Certainly you can mess around burning yourself, poking the coals around, even spritzing the charcoal with water to damp it down a bit (invariably dusting all the food with a light coating of tasty nutritious ash)
Not at all I had Charcoal BBQ for many years, and can cook fine on them thanks, it's just Gas BBQ's are better, and Wotan, No, you cannot taste any difference LMAO. The only thing different, is that when cooking on a charcoal BBQ, you resemble a black 'n' white minstrel, and smell like a petrol pump attendant
there is a distinct difference in taste, over wood it's far superior.
Wotan
Let me ask a question?there is a distinct difference in taste, over wood it's far superior.
Wotan
We'll have to disagree on that one![]()
Have you ever had smoked salmon, smoked ham, smoked cheese, kippers, if so where do you think these things get their flavour from?
I rest my case..
He who has reason on his side need not speak with loud voice.
Wotan
Better than being subjected to what amounts to cow flatulence, ie methane.Let me ask a question?
I rest my case..
Wotan
I believe they are all smoked at quite a low temperature, not charred black over hot charcoal.![]()
Better than being subjected to what amounts to cow flatulence, ie methane.![]()
Wotan
Give it up Wotan; this is an argument
