So, I have a 240V light above my shower which takes the standard GU10 type halogen bulb. Fitted by an electrician when I had my bathroom done.
Problem I have is that it's held in place by strong metal springs which clamp it to the plasterboard ceiling - everytime I need to change the bulb it's a bugger to remove the unit and some of the paint/plaster around the hole made to accept the light chips off. There is no way to replace the bulb without removing the whole light unit.
Am I missing something obvious or is this just inherent in this type of fitting? I wondered if there's a better type of unit to replace it with whereby the bulb is easy to change without removing the unit and bits of my ceiling! If there is such a thing am I allowed to fit it myself - it would appear simple to wire looking at the existing one but am aware it's electrics directly above a bath!
