Vokera Filling Loop
15 May 2005
Sussex
Does anyone know if Vokera still produce their trusty filling loop, the one with the two white headed chunky valves? My supplier can't seem to locate one and the 'net has drawn a blank.
for what boiler? i dont remember seeing anything like that on a vokera.
don't think they are available any more they were common on the older combi's but didn't meet the water regs if i recall.
They were used on older Vokera's I think the Valves were 15mm compression, so any filling loop valves should be ok as a repalcement, alternatively fit a new filling loop somewhere nearby shouldn't be a big deal :wink:
p.s. Just remembered which model it was - Vokera Flowmatic
Thanks Gents, apparently they are no longer available. The reason I wanted one was to fit for an elderly women. The big handles would have been easier for her to operate than the fiddly small levers.
Thanks anyway.
Thanks anyway.
could you not rig something up using 2 double check valves and quarter turn full bore lever valves
