D
dextrous
So, we are having a fire alarm system installed for the house we're renting - usual stuff (15 smoke/heat detectors, call points, control panel, 5 emergency lights).
Now, the spark who's fitting it is from New Zealand and has told me how far superior all his training etc etc etc , yawn yawn, yawn in comparison to UK and how he, if he bothered to do the uk assessments would be a "platinum" electrician. So, how come he's put a couple of the call points in the wrong places (we and his boss showed him where twice), and screwed a reset-key through embossed paper with a rather unattractive screw (how much are little hooks nowadays?
). Needless to say, moving the call points will make it impossible to hide the current positions due to the type of embossed paper/decoration.
But our main concern is that he has connected one of the emergency lights (in the cellar) to the kitchen ring circuit, in spite of us telling him that it would be better to connect it to the lighting circuit which the others are on which serve the hall/stairs/landing/cellar since, if the mcb or rcd tripped on this radial, then it would seem somewhat obvious to have the cellar emergency light come on to get to the CU, which is approx 6 feet away from this light with easy access to the exposed cables leading to it (he replaced the CU a couple of days ago, so is well aware of the layout)!
But the real mystery, which refers to the title of this thread, is why his connecting this cellar emergency light has been through the use of a multistrip connector with no cover/chockbox, which is (ironically) a fire hazard and will shortly become inaccessable once we overboard and plaster - of which he is aware. Clearly we have told his boss to send someone competent to repair and complete the installation. In the meantime, out of curiousity, which is a better repair to the cut in the kitchen ring main cable - crimping or solder/heatshrink?
