Mine has 5 cables (broken spring) and the replacement has only 3. (
Mine has 5 cables (broken spring) and the replacement has only 3. (![]()
3?![]()
Brown, blue and yellow/green?
You can get Honeywell V4043B and V4043C valves without the auxiliary switchI know it won't work, just never seen a valve with only 3 wires.
Did you buy it off Ebay? If so, that's tough - unless the advert was misleading. In which case contact Ebay.Thanks all, been seen off.
some OLD systems that had HW priority had them, as did some thermal stores.I know it won't work, just never seen a valve with only 3 wires.
you must be as old as me (well more or less)The old 'W' Plan IIRC
