E
EdwardCurrent
Hello All.
After failing to talk another 'homeowner' into not having downlighters I have come across a problem which I would like some advice on please.
7 X 50W GU10 fittings, (two-way switching).
http://www.screwfix.com/prods/48200...00VA-White;jsessionid=C15ZAKBYKBC0OCSTHZPCFFI
I fitted one of these only to have little or no response when bringing the lamps up to brightness, and when it does start to work the smooth dimming is overshadowed by the loud buzz !!!!
After buying it I noticed the lower rating , but thought that it would suffice .
However, am I right in thinking that because the rating is 75-800W that the lower range is not low enough ?
Would this do the job ??
http://www.tlc-direct.co.uk/Products/VL1000.html
How low do I need to go ? !!!!!!
Sorry for the drawn out post.
Regards and thanks
Ed.
Regards and thanks
Ed.
