New light & switch under the stairs cupboard
27 Dec 2005
London
We use the space in the cupboard under the stairs but have to fumble about in the dark. I want fit a light and switch there. The nearest electrical point is a two way switch in the kitchen controlling the kitchen lights. Is it possible to take a feed from this switch as this would mean a hole drilled through the wall from behind the switch into the cupboard to run the cable.
:idea: Please don't suggest any battery operated lights
solar? :?
It depends on whether you have access to a neutral in the back of the existing switch. Can't tell without looking.
It might be, but it probably isn't.
It will only be possible if:
a) Your lighting circuit is wired with the loop at the switches, not the ceiling fittings, or there won't be a neutral there.
AND
b) that switch has the cable running to the kitchen light, not just the strappers from the other switch.
So what does the switch have?
See http://www.diynot.com/wiki/electrics:lighting for details.
Unlike some people I don't carry disagreements from one topic to another - I'll react to mikhailfaradayski here on the basis of what he writes here, not on what he has written, or how he has behaved, in other topics.
