Converting an outside toilet
11 Jul 2009
Angus
Hi folks,
I have a (rather useless) brick built outside toilet. I was thinking of removing the toilet, and fitting a belfast type sink and using it as a utility area.
Broadly speaking, can anyone outline the plumbing fixtures i would need in order to do this? have never plumbed, and not sure what gizmos are out there to get this job done,..........
Many thanks in advance
has it got a water supply to it :?: What`s the colloquial name for that outside WC ...serously, is it a Cludgie :?:
In the mining garden cities north of the Tyne, its a 'cluggy' or 'ootside netty'. The open ouside drain of yore was called a 'cundie' :shock:
Now we call them 'garden facilities' :)
Cheers all, most intruiging,...................
Now back to the question :D
Any ideas?!!!
The current toilet is connected to the water system
Cheers
Then you can adapt the existing pipe to plastic and run it to a hose tap above the sink. Make sure it`s well lagged -you can get Talon pipe clips with spacers to make the pipe stand off the wall :idea: The tap can be on a wood block. Waste fitting is a special size for Belfast sink. Use a Hep V O valve under it onto 42 mm waste into drain adapter like Kev suggested. No trap ( U bend ) to dry out with lack of use that way :wink:
