G
Goldberg
What is the system pressure?The hot water tap is dripping at the valve.
Why am I not surprised?The system pressure is 1. The central heating stopped working yesterday and this morning the low pressure system light was on so that neither hot water nor heating was working.
What hot water problem? You said that it was fine.I drained the system and removed and cleaned the water flow switch. This seemed to fix the hot water problem
So, what were the original symptoms?but heating is still not working and I have this leak.
Because you didn't know what to expect in the first place?Why am I not surprised?The system pressure is 1. The central heating stopped working yesterday and this morning the low pressure system light was on so that neither hot water nor heating was working.
Isovalve needs replacing, but won't solve the problem.
First thing to check is the timer, followed by the roomstat.
Or the roomstat. Or the timer.Then replace the diverterIsovalve needs replacing, but won't solve the problem.
