Running a 12V appliance from a 230V mains supply
9 Oct 2009
Leeds
Hi people,
Here's my dilemma... I have an air compressor that runs at 10A, however it has a 12V cigarette lighter head on the power lead only enabling me to use it in a car. I really need to be able to use this compressor in the home. I have searched for adapters/transformers and the best I can find seem to run 1A appliances. I also looked into powering from my desktop's USB port however these can only support 500mA.
I'm at a loss as to what to do, any ideas would be much appreciated. I'd consider purchasing a new air compressor that runs from the mains if that turns out to be the cheaper alternative?
Thanks in advance,
Ross
You need a transformer thats capable of producing 10 amps continuous output...thats a pretty tall order and the nearest thing that I can think of is a heavy duty battery charger...fused, of course! These compressors aren't meant for continuous duty - ok for pumping a tyre up and thats about it. Cheers John :)
It should certainly work for short periods, yes. I'm desperately trying to think what percentage the RMS value against the maximum output but its gone....
I don't think your wee compressor should be run for more than 5 minutes at a time though.
What are you intending using it for?
You can buy mobile 12v power packs, some with built in compressors which may do the job you want, and they are a useful thing to have anyway.
