Want some advice. I am replacing an electric shower and need to put in some new plumbing for the mains water supply down from the loft. Should not be much of a problem but to ease some access problems is it ok to use some short flexible connectors (with 15mm compression joint on each end) as part of the pipework.
If yes, then could I use one at the end of the run to actually connect to the shower inlet pipe? (this would help considerably.
